E34 535 rocker snapped
charlE30
Post Sun Jan 06, 2008 10:30 am
My mate's 535 has snapped an exhaust rocker on cylinder No 6 (nearest the bulkhead) it looks like the previous owner hadn't tightened the eccentric adjuster and it slipped round closing up the clearance..
My question is do you guys reckon we'd be able to change it with the engine still in place as we only need to slid the rocker shaft about 2-3 inches to change it. I know we'd need to remove the radiator, front timing case cover, dizzy, timing chain and camshaft wheel and set all the valve eccentrics to maximum clearance. I can't see any issues unless we have to remove the rocker shaft end plate nearest the bulkhead.
Any input much appreciated :D
Charlie
BMW F31 335d xdrive
blitz877
AKA ajm-e30
Post Sun Jan 06, 2008 10:35 am
i dont see y not, iv done them like that b4
blitz877
AKA ajm-e30
Post Sun Jan 06, 2008 10:36 am
before*
Andyboy
Alpina Colada
Post Sun Jan 06, 2008 12:04 pm
No, can't be done without removing the head on the M30. There are four rocker shafts (two per side) and they are located in the head by the head bolts which engage in cut outs in the shafts.
Sorry, but it's head off time.
Don't even think about touching the downpipe studs as they ALWAYS snap off. They are special long shoulded bolts too. Undo the manifold from the head and remove the head with the inlet manifold. A good time to give the head a skim and a new gasket.
charlE30
Post Sun Jan 06, 2008 5:03 pm
Cheers for the information Andy, looks like I'll be busy next weekend then... Not all doom and gloom though as at some point this car was going to be going down the F/I route and this will give us the excuse of fitting an MLS headgasket and ARP head studs winkeye
Thanks for the head's up on the exhaust manifold aswell :thumb:
BMW F31 335d xdrive
