What parts (gaskets etc.) do I need to do a straight swap?
MrDazzle
Post Tue Jan 01, 2008 6:46 pm
Hi,
Got an oil pressure problem with my iS...I intend to fix it eventually, but for now I'm doing a straight swap with another E30 M42 engine to get the car back on the road. Then I can take the current engine to pieces at my leisure.
I've got a new block, head and sump arranged from a donor iS that was rear-ended. Obviously I have all the anciliaries and what not from my car, but what 'perishable' bits will I need. I'm guessing exhaust and intake manifold gaskets...what else?
Cheers muchly.
eko
Old timer
Post Tue Jan 01, 2008 6:48 pm
Worth changing the short fuel pipes under the inlet while you doing the swap :wink:
