front springs
JazzMan
Post Mon May 16, 2005 7:47 pm
I am trying to remove the springs from a set of front struts and am having some difficulty with it.
I've got a socket bit that fits the big bolt in the top and I have spring compressors in place, but now the damper is turning when I rotate the bolt and I cant see a good way to hold it in place.
Any advise would be much appreciated.
Patrick :)
Post Mon May 16, 2005 9:19 pm
I use a half inch 19mm socket, with a couple of flats ground onto the side, used with an open end spanner. ! then use a quarter inch socket on a short extension with a T bar, down through the hole in the 19mm socket, to hold the damper.
JazzMan
Post Tue May 17, 2005 12:05 pm
Brianmoooore wrote:I use a half inch 19mm socket, with a couple of flats ground onto the side, used with an open end spanner. ! then use a quarter inch socket on a short extension with a T bar, down through the hole in the 19mm socket, to hold the damper.
thank you :) I will give this a go tonight when I get home. Just need to get a spare 19mm socket to butcher!
TOURINGDADDY
Post Tue May 17, 2005 12:36 pm
HAVE YOU GOT A BLOW TORCH?????? IF NOT GET 1 HEAT THE NUT UP AND OFF SHE COMES NO MORE OF :cry: :x :mad: :cheese:
Post Tue May 17, 2005 1:48 pm
Doesn't fatally damage the 19mm socket. - Just a couple of flats to get an OE spanner on it.
JazzMan
Post Wed May 18, 2005 8:05 am
Thanks guys :thumb:
I had a blow tourch handy so I tried that first and it came right off without complaining :)
