Hi, I need delivered price for the following:
1990 318is M42
Expansion Tank 17111712835
GASKET RING 17211712965
GASKET RING 17111712966
Rubber O-Ring for Heater Valve connection into matrix possibly same as 64118377824 but not for same use. Need as fitted second-hand valve and now weeps slightly.
4x Studs and nuts for bolting throttle body to inlet manifold (I have heater plate assy so need longer type).
M-Tech Leather Gearknob with three stripes in top left corner for 318is.
10 x Door Trim Clip 51411870718
Clutch Reservoir Bracket 21521154741
Master Cylinder Repair Kit 21521156001
Bolt for Centre Console 07119901294
Plastic Bolt for Centre Console 51161932255
Many Thanks
Ben
Expansion tank and other bits
zimmerbimmer1
- BMW Parts Meister
Hi There Ben
prices as follows
Expansion Tank 17111712835 £26.75
GASKET RING 17211712965 £2.12
GASKET RING 17111712966 £0.95
Rubber O-Ring for Heater Valve connection into matrix possibly same as 64118377824 but not for same use. Need as fitted second-hand valve and now weeps slightly. £0.86
4x Studs and nuts for bolting throttle body to inlet manifold (I have heater plate assy so need longer type). studs £1.22 (FOR 4) Nuts £1.10
£32.54
10 x Door Trim Clip 51411870718 £1.27
Clutch Reservoir Bracket 21521154741 £1.94
Master Cylinder Repair Kit 21521156001 £34.03
Bolt for Centre Console 07119901294 £0.14
Plastic Bolt for Centre Console 51161932255 £0.15
prices as follows
£32.54
joker
Fantastic
Could I order all the above parts apart from the Gearknob (bit of a luxury at the moment!) and the Master Cylinder Repair Kit.
Not sure how payment etc works. Please let me know.
Ben
Ben
zimmerbimmer1
- BMW Parts Meister
for how to pay
click this
http://www.e30zone.net/modules.php?name ... 054#775054
please quote reference number 53962
click this
