318is into 320i shell
jimthejunior
Right basicly as the title, im picking up a 320 shell at the weekend hopefully and a 318is engine and box etc out of a crashed 318is. Apart from the engine loom what bits do i need, or any other bits i should taek? Cheers
kam-325i
the front struts from the Is.....
eko
- Old timer
Rear disc set up/anti roll bar
Front legs
Engine/box/prop/exhaust/radiator
Airbox/AFM and bracket
Coil pack and bracket
Think thats it
Front legs
Think thats it
maxfield
You won't need front legs or rear discs if the 320i has ABS
eko
- Old timer
oooh get you Maxmaxfield wrote:You won't need front legs or rear discs if the 320i has ABS
Only kidding,valid point made
kam-325i
But you'll need the 4 pot springs........eko wrote:oooh get you Maxmaxfield wrote:You won't need front legs or rear discs if the 320i has ABS![]()
