Hey all,
So, what's the best way to remove the black plastic inserts from post-facelift bumpers without destroying them? I've pulled both bumpers off the car and was amazed to see how complicated things are on the back side. Do the bumper guts have to be entirely disassembled, or is there some clever way to just pry/prise them out from the outside?
Thanks again.
Removing Bumper Inserts
KDS
-KDS in Vancouver ('88 325i Touring)
kevin316i
The clips on the back of the bumper strips are very prone to breaking, so if you are prising them off it needs to be done very carefully, and even then there is no guarantee that they won't break.
Ideally, if you could get access to them from the inside of the bumper then you could push them out rather than pulling form the front and this would minimise damage. However, I don't know if this is possible.
Templ8e30
The insert clips can be accessed from the inside of the bumper through the small holes in the bumper carrier.
Use a small screwdriver and prise them whilst pulling from the other side.
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
They still break though. Getting the bumper nice and warm might make the plastic a little less brittle. (Theory only - not tried)
KDS
So, do you guys think that instead of disassembling a perfectly good bumper for painting, it'd be better to just keep it assembled and do a good masking job?
Templ8e30
Well, I've had the capping off mine 3 times to fit a custom made removable towbar and all the clips are unbroken.
Maybe I'm just delicate
Cheers,
Iain T
Cheers,
Iain T
