325i wheelspin auto
joeyboysbmw
Mon Nov 12, 2007 9:36 pm
hi this is my first post
i have a e30 325is m tech automatic in diamond black.
it has 17 alpina replicas on it.
the car goes well but i think it might not be producing the power it should.
i say this because ive seen the same cars with the same size wheels in autos put there foot down and spin up in the dry.
my car cant do this. (burn out or donut) which concerns me. or is this normal?
thanks
joe.
Nelly
Gumbo
Gumbo
Mon Nov 12, 2007 9:42 pm
Do the enevitable and hold her on high revs in neutral then slip it into 1 - warning though, prolonged usage of this manor will easily blow the gear box like i found out on my trusty 2 ltr 'Loner'
"I F**KING LOVE YOU GUMBO"
joeyboysbmw
Mon Nov 12, 2007 9:50 pm
dont get me wrong i dont whish to abuse my car by smashing it into gear.
but i thought these cars would burnout if you step on the brake and load up the torque converter
or on full lock donut but seriously nothing.
even in the wet it will go round onec but then the revs drop?
surely this aint normal.
bloom_meister
Mon Nov 12, 2007 9:55 pm
You sure no-one popped a 318iS in the hood when you wasnt looking? :D
Runs...
joeyboysbmw
Mon Nov 12, 2007 9:59 pm
no
its had a recon box and torque converter.
and the full head was recon like 3 k ago.
but i cant belive it cant turn the wheels.
a friend had a normal 325i with 15 on it and it used to spin up pice of piss.
Nelly
Gumbo
Gumbo
Mon Nov 12, 2007 10:02 pm
Don't stand on the brake pedal to burn out , it only requires light application and a 325i manual or auto to smoke regardless - if this isn't the case i'd look into who fitted the torch converter
joeyboysbmw
Mon Nov 12, 2007 10:05 pm
what in the dry?
i dont mean im pushing it hard any way just a figure of speech.
wicked quote love that film.
Nelly
Gumbo
Gumbo
Mon Nov 12, 2007 10:06 pm
Dry or wet fella she should smoke up.
Cheers on the quote, not alot of ppl have quest it yet.
joeyboysbmw
Mon Nov 12, 2007 10:07 pm
its like as the wheels go to turn the engine wont keep reving up.
Nelly
Gumbo
Gumbo
Mon Nov 12, 2007 10:11 pm
torch converter issues??? did you get the proff of work receit from when it was replaced? either that or you've got some seriously sticky rear tyres on her - on full lock and locked in 1 and given space - she should do what you want her to do
joeyboysbmw
Mon Nov 12, 2007 10:13 pm
ive just had a look at te dics front. there worn pads are ok but disc have seen better days.
does anyone think this cold be making the back wheels lock up slightly when im on the brake?
still this wouldnt explain why it cant donut in the dry.
joeyboysbmw
Mon Nov 12, 2007 10:17 pm
it has got toyos on it.
i have a reciept for £900 for a recon box and converter. less than 2000 miles ago.
Nelly
Gumbo
Gumbo
Mon Nov 12, 2007 10:21 pm
Most of the braking goes to the front calipers on an E30 so, giving that your front pads arn't completly shagged and the discs are as thin as a CD i'd say that slighty worn pads arn't going to be the problem.
The cold will have nothing to do with this situ either fella.
It all comes down to 'Torch' regardless of what bhp your engine is running - this is why i asked about your torch converter work - it sounds as though the engine is struggling to put it to the drive of the rear wheels. The only stuggling point would be the torch converter.
1an
you wont be able to donut properly unless you have an LSD or a welded diff.
Cotty
Hartge Crew
Mon Nov 12, 2007 10:23 pm
joeyboysbmw wrote: i say this because ive seen the same cars with the same size wheels in autos put there foot down and spin up in the dry.
I have never managed to get my 325i auto to spin its tyres in the dry. I dont have an LSD so in the wet/damp I can get one wheel spinning.
1an
Mon Nov 12, 2007 10:30 pm
i can get my 316 to spin the tyres up in the dry. anything is possible, just try harder.
joeyboysbmw
Mon Nov 12, 2007 10:31 pm
i think the car has a lsd.
i put the car in first turned it on full lock and just keept going and all it done was push the front wheels out.
the car seems to go quite well it kicks down and goes.
but i know that ive seen at least 2 autos spin up. 1 i dont know what he had done to itbecause he just put his put down and it started wheel spining with 17. the other had 15 but was standard.
joeyboysbmw
Mon Nov 12, 2007 10:44 pm
Cotty
are you saying that this is how the auto 325is go?
Nelly
Gumbo
Gumbo
Mon Nov 12, 2007 10:46 pm
It is harder for an auto admittidally but none the less she should spin - at the very least in the wet on full lock.
I watch about a year ago now a guy called "Jimbo" take out another Zoners car which was a 4 door 325i auto on an open diff an donut it properly for a good few mins - he did start in a hugh circle and decreased it but got it in the end.
Cabbies tend to push their front wheels out due to the chassie weight but i'm guessing you've got a rare 325i sport switchable auto??
joeyboysbmw
Mon Nov 12, 2007 10:49 pm
thats the 1 with the e s 321 .
is there a way i can post a pic of the car .
sorry im new to this.
Cotty
Hartge Crew
Mon Nov 12, 2007 10:51 pm
1an wrote:i can get my 316 to spin the tyres up in the dry. anything is possible, just try harder.
I have spun the wheels on my 316 and spun it , lost my 325i auto in the wet so anything is possible.
joeyboysbmw
my old man had a 540i and that thing would spin up if you just kicked down
Nelly
Gumbo
Gumbo
Mon Nov 12, 2007 10:52 pm
joeyboysbmw wrote:thats the 1 with the e s 321 .
Email the pics to neil.greenwin@ntlworld.com and i'll host them up for you
But yes, that a switchable auto box - that sucker should spin up regardless given slightly more effort than a manual! - - - - - torch converter again fella springs to mind.
1an
Mon Nov 12, 2007 10:53 pm
laps of roundabouts in my 316 is quite fun, obviously on private roads, bring on the welder.
joeyboysbmw
Mon Nov 12, 2007 10:57 pm
only got 1 on computer at the mo sent it to ya thanks.
Nelly
Gumbo
Gumbo
Mon Nov 12, 2007 11:07 pm
And here she is in tasty looking form and the best colour imho;
Nelly
Gumbo
Gumbo
Mon Nov 12, 2007 11:08 pm
Where abouts are you from fella?
joeyboysbmw
Mon Nov 12, 2007 11:10 pm
south east london.
joeyboysbmw
Mon Nov 12, 2007 11:11 pm
shes dirty inthat pic. nice tho?
Nelly
Gumbo
Gumbo
Mon Nov 12, 2007 11:15 pm
Are you far from 'Orpington' J4 of the M25??
joeyboysbmw
Mon Nov 12, 2007 11:17 pm
no mate about 30 mins if that
Joshy
Mon Nov 12, 2007 11:27 pm
Great, another member of the south east london club.
Sorry I can't help you with your problem, but it's nice to see people with e30 down these sides.
Nelly
Gumbo
Gumbo
Mon Nov 12, 2007 11:28 pm
OK, you need to get intouch with a guy called "Ant" - a moderator on here with the same user name, he runs a firm called "Atech" which specilize in E30's and is based in Orpington with a bag of knowledge - he'll come highly recomended by me and any other user on here and i'm sure he'll be able to diognose your problem for you (I'm gonna stick with torch converter).
p.s. he lives for "Hob Nobs"
Nelly
Gumbo
Gumbo
Mon Nov 12, 2007 11:31 pm
To save you the trouble;
joeyboysbmw
Mon Nov 12, 2007 11:33 pm
thanks buddy.
