hi.
what parts are available for these?
i'm looking to do a rebuild or two and will need shaft seals, backplate gasket, input bearings and crush sleeve at the very least. are more bits available or does it then pass over to an exchange unit?
gareth
medium case LSD bits
- zimmerbimmer1
- BMW Parts Meister
gareth
ok, can i have prices on the following please?
SHAFT SEAL 33101214099
TAPERED ROLLER BEARING 33121203615
TAPERED ROLLER BEARING 33121203616
CLAMPING BUSH 33121744368
SHAFT SEAL WITH LOCK RING 33107505602
TAPERED ROLLER BEARING 33131213893
O-RING 33111214144
GASKET ASBESTOS FREE 33111210405
cheers
gareth
O-RING 33111214144
cheers
gareth
