disco oil
bodger
Post Thu Nov 01, 2007 6:52 pm
my dads disco has the bmw td5 engine, its on a w reg, apparently it should have 5/30 oil in it, the one from gsf is said to be for ford engines, does this matter and is it the right grade anyway :?
Post Sat Nov 03, 2007 10:36 am
Discoveries , unlike nasty P38 rangerovers never had the BMW 6 cylinder diesel. Being a landrover nasty leaky tractor engine i wouldn't have thought what oil you added was of great importance, it will be on your drive shortly anyway ! :eek:
Andyboy
Alpina Colada
Post Sun Nov 04, 2007 12:11 am
Indeed, early ones up to about T reg have the four pot Dorothy Perkins motor. Later ones are 5 pot, both are 2495cc. The early ones give excellent chassis lubrication. :D
Post Sun Nov 04, 2007 12:14 am
Chassis lubrication, I like that one :P
Andyboy
Alpina Colada
Post Sun Nov 04, 2007 12:18 am
They're not a bad engine to be fair. The TD5 is a five cylinder version of the Rover L series motor which itself is a development of the old Perkins Prima which powered Maestros and Montegos. The Montego version was turbocharged and went very well with good economy and was as tough and reliable as diesels should be. This was itself was a dieselised version of the Leyland O Series 1700/2000 motor which came out in 1978 (Hmmm, Marina, Ital, Princess....).
Here the lesson endeth.
