Is Waxoil in aerosol form any good.
biggee
Post Fri Oct 26, 2007 8:33 am
I'm just adding the finishing touches to cleaning under the arches and figured I'd re waxoil them. It's either buy a proper kit with spray gun etc or use the small aerosol's. Does anyone no if there anygood?
bazza93
Post Fri Oct 26, 2007 8:42 am
can't see a problem there :D aslong as you make sure you give it a good shake to mix it properley and spray it in all the nooks and cranies :)
will be back in an E30 oneday soon !
THE BMW 3-SERIES. IT'S WHY SOME ENTHUSIASTS ARE MORE ENTHUSIASTIC,
biggee
Post Fri Oct 26, 2007 9:05 am
So what are you saying Bazza. Have you used it or not !!!
bazza93
Post Fri Oct 26, 2007 9:14 am
a long while ago
Post Fri Oct 26, 2007 10:47 pm
It is fine, i used it on my sport after i had it painted. Used about 10 cans kindly donated from the stores at work! winkeye
A pressure fed wax oil gun would be better for hader to get to places like inside sills and chassis rails.
gare30
Post Sat Oct 27, 2007 3:55 pm
its alot thinner than the proper stuff i use it in work seems ok wen dry just got to put loads on usualy comes with a bendy long nosel to get into awkward bits and cavitys
Post Sun Oct 28, 2007 8:06 am
I rate it for local stuff where a proper air fed wax gun would make a real mess. They are ideal for exactly what your doing. Just apply it to where they all rust, on the inner lip all the way round.
You would never fill a sill cavity effectivly with one though. Thats where a proper wax guun comes in.
