m20 sump
tommye30
Fri Oct 26, 2007 1:45 am
Can anyone tell me if any m20 sump will fit on my 325 and will an 325 engine with an auto box bolt strait up to a manual box cheers TOM :mad:
**BANNED**
Fri Oct 26, 2007 11:12 am
You need an ally E30 sump,the pressed steel type fitted to E28's will not fit.When I did my 2.7 conversion I started with a manual 320i and an auto 525e.I used the 320 flywheel,clutch and gearbox on the 525e block.
Youth is wasted on the young.
HairyScreech
Fri Oct 26, 2007 2:21 pm
what 2.5 engine does your 325 have?
what auto engine and what manual box?
:mad:
Templ8e30
Fri Oct 26, 2007 8:03 pm
You'll need to fit a spigot bearing in the end of the crank and fit a manual flywheel/ and clutch but it will fit.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
tommye30
Sat Oct 27, 2007 2:44 am
what do you mean by what engine it is hairyscreech?
