324 td no power!
Nuno318is
Tue Oct 16, 2007 11:34 pm
hallo
i have 324td and the car doesnt speed as a normal turbo car makes.
it doesnt make any kind of smoke, and the turbo looks fine.
Can any budy help me
sorry for my english.
greatings from Madeira-Portugal
www.bmwmadeira.org
Jesus325iTouring
Frog freak !
Frog freak !
Wed Oct 17, 2007 12:30 am
I'm not familiar with turbo diesels,I did once sort out a turbo diesel engine that had lack of power even though the turbo was OK.
It turned out to be an air leak on a pipe.
So with that in mind,check thoroughly all your pipe work around the turbo,maybe have someone in the car revving it whilst you check for leaks.
Nuno318is
Wed Oct 17, 2007 1:22 pm
:thumb:
thanks i will check
www.bmwmadeira.org
abelai
Thu Oct 18, 2007 4:54 pm
Another common problem with bmw diesels is the lift pump in the tank doesn't work properly and the injection pump is left to do all the work, car will normally also be bad at starting will low fuel loads.
If I can't fix it I'll f**k it up so bad nobody can!!
stuartgallafant
Thu Oct 18, 2007 8:06 pm
air leak either before the turbo or after the turbo could be a good start. As abelai said, this is also a known fault of diesels this age
Nuno318is
Fri Oct 19, 2007 2:39 pm
thanks to all
I check the turbo and theres a leak before the turbo, im wating for the new pipe to see if thats was really the problem.
I dont think lift pump in the tank is a problem because the engine runs at the first start on the engniction, but i'll see any way.
The rpm dont work, and i allready changed the dash painel, and also the lights of inspection is on all teh time?!
I dont think thats normal! or is it??
www.bmwmadeira.org
