TouringMatt
Post
Sat May 07, 2005 11:45 am
Cos mine sits ~800rpm regardless of if the engine is warm or cold!
Blue ECU temp sensor in the thermostat housing?
Matt
smithy318i
Post
Sat May 07, 2005 1:03 pm
Erm... The ICV !? (idle control valve)
well mine does anyway.
cros
Post
Sat May 07, 2005 5:20 pm
Yes the ICV is responsible for the constant & steady idle speed. Under ECU control, the revs can be raised up a bit, kind of like a 2nd throttle.
Play with it by getting the integral error to wind up: when warm, slowly let the clutch out with the handbrake on in 1st. The ICV will open more & more to maintain 800rpm (and prevent stall). When you find the limit of what the ICV can do, press the clutch down fully and see how it rises to 1500rpm for a second or two while the control loop readjusts and shuts the ICV.
I think the temperature sensor is to enable overfuelling when cold. I imagine that the ICV is just a closed loop setup based on revs.
TouringMatt
Post
Sun May 08, 2005 2:06 am
Tried this, revs dipped to about 500rpm, clutch down and it just goes back to 800rpm without the 1500rpm rise.
Gonna re-test the IVC but im sure ive done this before!
Matt
Andy_magic
Post
Sun May 08, 2005 5:00 pm
Yeah the blue temp sensor is for cold starting, if disconnected the ECU assumed its cold.
Carb cleaner and toothbrush time for the ICV I reckon
A1BMW325iSport
Post
Sun May 08, 2005 6:12 pm
anyone know how much a new ICV is?
smithy318i
Post
Sun May 08, 2005 6:20 pm
Ԛ£85.19 or Ԛ£91.65 depending on engine (eurocarparts)
probably about Ԛ£10 from a scrappy.
amit325i
Post
Sun May 08, 2005 7:16 pm
if its sitting around 800rpm its fine, it will be lumpy at idle all motronics are like by now! I wouldn't worry about it.
TouringMatt
Post
Mon May 09, 2005 10:07 pm
Did some testing today!
IVC has correct resistance and the internals move nicely, but something is not right with the incoming voltage.
Center of the 3 pins reads 12v as it should, the two outer ones read 4v and 9v where according to the Haynes they should both be about 10v each
ECU snafu'd?
Matt
Andy_magic
Post
Mon May 09, 2005 10:35 pm
My take on that problem was that the ECU drives both sides of the ICV solenoid to get a particular amount of opening.
I don't think a standard DVM will be able to read the ECu outputs to the ICV accurately as it's a pulsed signal, no steady voltage. You would probably need an osciloscope to see if all is well.
That, coupled with the fact that the haynes manual is full of errors and the fact I was getting 3v & 11v on my car that idles well hot or cold should point to the ECU being OK.
I also think the motronic ECU's are very reliable and are rarely the cause of a fault, they seem to either work or not.
You really need to isolate any possible mechanical problems such as air leaks, carbon/oil build up on the ICV, all the sensors giving correct readings etc.
My latest E30 ran like a bag of sh1te when I got it, there were 3 main problems with it:
Dodgy thermostat running the engine too cool
Dead blue temp sensor
Wiring from blue temp sensor was dead, so the ecu thought it was always cold.
A1BMW325iSport
Post
Tue May 10, 2005 2:36 am
i was lucky i got a virtually new icv off the touring at the breakers today
TouringMatt
Post
Tue May 10, 2005 10:45 pm
Yeah i think thats what i need to do, not entirely convinced i have zero air leaks as when giving it some beans im sure i could hear a high pitch sucking noise today, and i need to take some readings on the blue temp sensor.
Thanks for letting me know you got similar readings off your ECU, the Haynes is a bit hit and miss sometimes
I'll let you know how it goes
Matt
TouringMatt
Post
Thu May 12, 2005 8:04 pm
Ok, i took some temp sensor readings at cold today.
With the meter set on 20k i got 3.031 is that right?!?!
Checked the wiring from plug to the multiplug that sits kinda under the inlet manifold and its ok
Fired the car up and it still idles at 800rpm at cold and splutters if i try and rev it quickly
Thoughts
Matt
Andy_magic
Post
Thu May 12, 2005 8:15 pm
You really need to check the wiring all the way back to the ecu. the easy way to do this is to pull the blue sender wire with the engine hot, if it starts running bad the wiring is ok, if it stays the same you got wiring problems.
Spluttering when going from idle to open throttle can be due to badly adjusted CO, go and bribe your MOT inspector and get it checked out.
This spluttering is common on E30's but it can be sorted.
The engine managment on E30's is pretty basic but for the engine to run 100% everything must be right, it's also very easy to hide one problem by messing about but you can introduce others.
I'm still writing a how to on the E30 6 pot engine managment, I've just got to take a few photos and do a few finishing touches and I'll publish it.
