HOT TOP , COLD BOTTEM
jibbers
Post Fri May 06, 2005 9:13 pm
This is what i have after my coolin system bang earlier , im on about rad pipes , does this mean that the thermostat has seized shut ?
Or could it be a block in the rad ?
jibbers
craigieeb
Post Fri May 06, 2005 9:21 pm
undo the bleed bolt on the thurmostat and see if the is any blockages, and you could just take out the thermostst and pour some boiling water over it to see if it opend,
iv just had the simmilar problem with mine mate i just replaced the thermostst and the waterpump just to be on the safe side and all turned out well
the parts are prity cheap from euro car parts. hth
jibbers
Post Fri May 06, 2005 9:27 pm
I was gonna try the stat next , did not think about the water pump tho .
where is the WP , IBET IT RUNS OFF THE CAM DONT IT !
Also did you buy each item new ? if so how much where they ?
Cheers Craig
JIBBERS :?
craigieeb
Post Fri May 06, 2005 9:29 pm
aaannnddd check your return pipe to the header tank for blockages, be sure to check the bit that the pipe attaches on to aswell mate
craigieeb
Post Fri May 06, 2005 9:32 pm
jibbers wrote:I was gonna try the stat next , did not think about the water pump tho .
Cheers Craig
JIBBERS :?
nope the water pump runs off the altonator belt mate (replace that aswell)
http://www.euro-car-parts.com/
alll worked out quite cheap realy
jibbers
Post Fri May 06, 2005 10:43 pm
All sorted , it just turned out to be a shagged thermo , its all sorted now , i put the one in from an old 320 i got layin about , mine is a 325 , it had the same dimensions so i cant see a prob .
P.S. THE MISSUS WANTS TO KNOW IF YOUR A SAND DANCER ?
WHERE YOU FROM ?
:lol: JIBBERS
craigieeb
Post Fri May 06, 2005 10:58 pm
jibbers wrote: P.S. THE MISSUS WANTS TO KNOW IF YOUR A SAND DANCER ?
WHERE YOU FROM ?
:lol: JIBBERS
glad its sorted matey
and
:lol: :lol: no im not from south shields im actually living in longbenton
jibbers
Post Sat May 07, 2005 12:22 am
Your name wouldn't be Craig Brett would it ?
Jibbers
craigieeb
Post Sat May 07, 2005 2:22 pm
:oops: what ever you'r missus says iv done it wasnt me honnest :oops:
craigieeb
Post Sat May 07, 2005 2:24 pm
:lol: seriousley tho its not craig brett : )
