outside temp sensor
DaveD
- E30Zone Wiki Specialist
My computer has started to tell me its 5f or 12 f and sounding its gong......... any clues.. maybe it doesn't like me having the top down
cros
That's the symptom of the temerature sensor being disconnected or having bad contact. Could be a bad sensor (unlikely), dirt in the plug or just a chafed wire.
Big resistance = low temperature.
Theres a 2 wire plug behind the glovebox which connects to 2 wires which run through the bulkhead, along the inside left wing and down to the sensor in the brake ducts. Check all of this.
Shorting the 2 wires together should register as +70deg celsius. Useful for testing the OBC and its connections.
Davenotouring
Probably the temp sensor has gone a bit mental.
It sits in the passenger side brake duct in case you didn't know..
BMW 328i Cab - Daily Slag
DaveD
ta
will check it later as per instructions
Davenotouring
Cros with the technical description caned my 'It's fu**ed, put a new one on'!!
cros
I aim to close off topics with my er... descriptive descriptions.
