Going to buy a set of borbet a 16' front 7 1/2j and rear 9j will
the rear fit and what tyre size car is lowered 60/40
Borbet A
i think you ok with 215s on the rear
i have 225s on mine but theyre 7.5" borbets not 9s
www.oldskoolfantasy.co.uk
Is your car lowered and if so did you have to roll the archesjaburna wrote:yeah they'll fit no problem. Im running the exact same set up.. 16x9 rear and 16x7.5 front w/215/40 tires all around
Any more help
diff wrote:Is your car lowered and if so did you have to roll the archesjaburna wrote:yeah they'll fit no problem. Im running the exact same set up.. 16x9 rear and 16x7.5 front w/215/40 tires all around
http://www.maxbimmer.com/forums/showthread.php?t=54146 read this thread, it should answer most of your questions
