e30 4 stud to 5 stud
ac
Post Sun May 01, 2005 9:09 pm
dose any one know if there is a way of converting a 325i cab from 4 stud to a 5 stud hud. as I want to put on some bm 5 stud rims.
will a 525i from the same year do for a converison and what items do i need to replace.
ac
Sjoerd320i
Post Sun May 01, 2005 9:11 pm
for as far as i know the 5 series parts dont fit a e30 you'll need the parts from a e30 m3 or any kind of e36, but someone else can probably give you more info about it
cheers Sjoerd
Post Sun May 01, 2005 9:50 pm
either find all the bits from an M3 or you can use z3/compact rear end bits with e36 front legs altho you have to do stuff like offset bushes n arms and neg camber top mounts to get the geometry back to normal
ac
Post Mon May 02, 2005 5:40 pm
thanks
