On the 325, did one side no problem, but I cant get the other to shift at all. Tried everything I can think of. Anyone know of any other methods?
Brake caliper pistons - need to compress!!!
karlp
Try releasing the bleed screw, placing on a small piece of wood then use another piece of wood the other side of the caliper and tap lightly with hammer. Beware that fluid will come out of the bleed screw.
Obviously make sure no air goes into the caliper or safer optioin is to bleed it slightly.
Karl
Karl
smithy318i
I always find brute force usually works.
If your bleed nipple is fcuked then
loosen the cap on the filler bottle
put the top pin back in the caliper, rotate upward, place a small (thin) piece of wood in the gap and jam a claw hammer between them, then pull (hard)
you could try some PTFE on the piston too (WD40)
E30Adam
Get a G-clamp on the piston and wind it back in, easy!
Turbo-Brown
- Boost Junkie
Never, EVER use WD40 or any other type of grease or oil on brake components!
It perishes the seals leaving you with no brakes!
You can get a special lube from lockheed and the like which doesn't harm the seals, but it's more for assembly than getting stuff going again.
smithy318i
I was told the oposite! oil based lubricants protect the rubber components.Turbo-Brown wrote: It perishes the seals leaving you with no brakes!
any other views?
Turbo-Brown
- Boost Junkie
Oil may well protect rubber components like oil seals, but you try soaking a seal from the brake or clutch system in WD40 or oil and it will swell up and then fall apart
There are special lubricants for use in the brake system for a reason!
Sorry if I sound a bit harsh, but I've seen a few people recommend using WD40 on braking systems and it's a fcuking massive no-no!
Oil seals and the like are neoprene, not rubber.
Rubber (as used in brake components) is attacked by mineral oil and similar.
As turbobrown says, keep oil and brake components apart.
You should always open the bleed nipple on a caliper when you retract the piston. If you don't, it forces dirty brake fluid back into the system, can invert the seals on the master cylinder, and on some makes of car, will damage the ABS unit.
johnono
did that, and it was soooo easy compared to all the other idiot methods we tried firstE30Adam wrote:Get a G-clamp on the piston and wind it back in, easy!
Adammcf
I just took mine off and forced the piston in by pushing really hard on it with the end of a hammer.
hoshy
- E30 Zone Wiki Guru
I did my pads on Friday. I used the wheel brace... just wedged it in there and pushed
Adammcf
LOL! I tried that one too but the end wasnt very friendly for pushing against so the hammers flat edge worked better.
