CAN ANYONE HELP MY
blackbitch
Sun Aug 19, 2007 2:35 pm
Dose any one know where the central locking relay is in my 318 as my central locking has stopped working. I can open all my doors by hand but not my boot.
CAN ANYONE HELP MY
Thanks to ImageShack for Free Image Hosting
dazleeds
old skool raver
old skool raver
Sun Aug 19, 2007 2:41 pm
behind the drivers side speaker in the footwell
remove cover and speaker then undo the 2 10mm nuts and pull the relay up from behind speaker its fitted to a triangular metal plate
ps you sure you havent turned the key to fully locked on the boot?? full to the right
if you have just turn it back left so itll relaease from the central locking again
www.oldskoolfantasy.co.uk
eko
Old timer
Sun Aug 19, 2007 2:46 pm
If the relay doesnt sort your problem then the Back/Red wire trick probably will winkeye
Use the search button to find out how to do it!
Cloggy Saint
Sun Aug 19, 2007 2:47 pm
Cut the red/black wires that do a loop inside the relay and join them together, it's a common failure.
grantfk10
Sun Aug 19, 2007 5:20 pm
eko wrote:If the relay doesnt sort your problem then the Black/Red wire trick probably will winkeye
It worked for me when my central locking stopped working totally. :wink:
Simon
Sun Aug 19, 2007 7:52 pm
Moved to the tech section.
Sun Aug 19, 2007 7:56 pm
datourer wrote:Cut the red/black wires that do a loop inside the relay and join them together, it's a common failure.
Loop inside the door even :D
