e46 top mounts, damned fine
thesaint
Thu Aug 16, 2007 12:04 am
just put those e46 top mounts ojn, good, probably cos mine had fallon to peics put it wa very good and reccomend it to anyone.
1986 325i - Gone. 1993 318i touring, m52 in the planning stages.
Demlotcrew
Thu Aug 16, 2007 12:06 am
From BMW?
thesaint
Thu Aug 16, 2007 12:08 am
yes.
Greeny
Thu Aug 16, 2007 12:12 am
Whats the difference between the e46 top mounts and the e30 ones?
Gone but not forgotten.
('92 325i Cabriolet)
sleepenvy
Thu Aug 16, 2007 12:13 am
do they have any negative camber on them?
320Touring
Thu Aug 16, 2007 12:22 am
Greeny wrote:Whats the difference between the e46 top mounts and the e30 ones?
e30 ones have the metal sleeve on the rod of the damper, e46 cab oned have it moulded into the mount. less likely to part company.
firmer rubber too-well worthwhile mod!
tezk
Thu Aug 16, 2007 12:25 am
Zimmerbimmer1 on here can supply top mounts at £22 ish. Well worth the money!
Will be £41 ish with reinforcing plates, though zedone might have a few reinforcing plates left:
http://www.e30zone.net/modules.php?name ... ic&t=71236
I have a pair to fit - look excellent quality!
ian332isport
Thu Aug 16, 2007 9:11 am
sleepenvy wrote:do they have any negative camber on them?
Whatever you do with the rear top mounts, it won't change the rear camber. You can only change the rear camber with eccentric trailing arm bushes or a modified rear subframe.
Ian.
Bob_S
Thu Aug 16, 2007 9:34 am
i just picked up mounts and plates for £33? gen bmw from the dealer?
Bollocks to this 24v scrap!
