It's the 'spigot' in the centre I need to know about, I'm assuming the stud pattern is ok, I don't want to use the wheels, only the discs.
TIA.
e34 will go straight on, obviuosly tyre profiles will be different. To use e39 wheels you will need hub centrics rings. You can get these from www.tirerack.com based in the US for not much money. I saw an advert in the back of PBMW for a UK company selling them for around Ԛ£25 a set.M3Compact wrote:Does anyone know if 5 series, E34 or E39 wheels will fit on an E30 M3 hub ok?
TIA.
