stereo fitting problem **Pics added**
redchurch
Post Sat Aug 11, 2007 9:08 pm
I recently removed an old Blaupunkt cassette/radio player from my 1989 316 which was easy enough. However this stereo is much shorter than the new one i've bought so the new one sticks out the dash quite a bit. Any ideas how to fix this?
tomtomiS
Post Sat Aug 11, 2007 11:04 pm
make sure that the cage isnt stopping it going all the way in, also look to see if the wiring harness is trapped at the back under the heating ducts.
redchurch
Post Sun Aug 12, 2007 12:06 am
I've tucked the wire away nicely, it just seems the gap isn't deep enough. The old stereo is quite a bit shorter. Is this normal for E30's, is this how the factory stereos come or is it some kind of adaptor?
touringandy
Post Sun Aug 12, 2007 9:30 am
i found there was a form of black plastic bracket stopping mine just broke it of ,but found it may
of bin a stabilising bracket ???for the stereo???
tomtomiS
Post Sun Aug 12, 2007 9:44 am
all headunits made these days conform to an industry standard, i think the size is DIN E. any single din stereo will fit in an e30. ive had 4 different e30' :mad: s and approx 8 or 9 different headunits ( all in all) and they have all fitted in nicely. have a very good look and make sure no wires or anything is getting in the way. its a couple of minute job to take out the headunit and put in a new one. make sure there is nothing in the way of the stereo, thats all i can say
jcjdavis1
Post Sun Aug 12, 2007 9:58 am
Hi have you dropped the glove box and taken out the plastic trim to have a look?
Hi Plenty of room to have a look and check things out.
redchurch
Post Sun Aug 12, 2007 12:59 pm
From your replys it seems there is probally a special bracket fitted for the old stereo. It didn't have any wires coming out of it, there is just a plug in the back of the gap which the old stereo was pluged directly into. I put the adaptor that came with the stereo into this, tucked the wires away but with the old stereo being shorter it'd only push in up to the same point as the old stereo.
What's the best way to get a look at this? Take the glove box out?
redchurch
Post Sun Aug 12, 2007 5:40 pm
I took the glovebox to get a better look and took these pics:
This is about as far as it goes in at the moment:
Here is the panel I took off, although I couldn't get the back unhooked
Some shots of the inside. As you can see the connected has been mounted inside the bracked for the stereo and won't budge. It looks like the normal bracket that clips around the stereo goes all the way back and the plug is built in:
jcjdavis1
Post Sun Aug 12, 2007 6:56 pm
Hi I would take it all out including the cage and start from scratch. Use the cage that came with the radio, but do the wiring first but keep it out the way. Try the radio without the cage to see if it fits and fix the obstruction, then put the cage in, then the radio and then plug the wiring in just before the radio clicks into place. Once in place there is usually a plastic cover that fits around the radio to hide pin holes.
redchurch
Post Sun Aug 12, 2007 8:27 pm
jcjdavis1 wrote:Hi I would take it all out including the cage and start from scratch. Use the cage that came with the radio, but do the wiring first but keep it out the way. Try the radio without the cage to see if it fits and fix the obstruction, then put the cage in, then the radio and then plug the wiring in just before the radio clicks into place. Once in place there is usually a plastic cover that fits around the radio to hide pin holes.
Ok sounds good, how do I get the cage out?
jcjdavis1
Post Sun Aug 12, 2007 8:51 pm
Hi Use a small screwdriver and bend out the small tabs all round the cage.
redchurch
Post Sun Aug 12, 2007 9:15 pm
jcjdavis1 wrote:Hi Use a small screwdriver and bend out the small tabs all round the cage.
I tried that when I first fitted the stereo but it didn't work, it seems to be connected in some way at the back. The plug looks almost like its hardwired into the case.
Post Sun Aug 12, 2007 9:23 pm
You've still got the black blaupunkt cage in there. You new unit will never fit with it in place. You need to remove that whole black cage and fit the cage that your head unit came with, in it's place.
The Blaupunkt cage will be held in by bent tabs at the front (as has been explained above) and it may also be bolted at the back but I doubt it.
jcjdavis1
Post Sun Aug 12, 2007 9:26 pm
Hi You might have to take the wiring loom out which starts behind the glove box.Have a look at this link and you might get some ideas.
http://www.e30zone.net/modules.php?name ... ic&t=57325
redchurch
Post Sun Aug 12, 2007 9:44 pm
B7 wrote:You've still got the black blaupunkt cage in there. You new unit will never fit with it in place. You need to remove that whole black cage and fit the cage that your head unit came with, in it's place.
Yeah I think it is the blaupunkt cage, I bent the front of it up trying to get it out but it's held in by something at the back. It might just be the wire, if you look at the pics the black box at the back was in the cage for the old stereo and won't just push out the back.
grantfk10
Post Mon Aug 13, 2007 8:20 pm
Surely if you remove the whole blaupunkt cage (as said above) it'll fit?
Post Mon Aug 13, 2007 9:41 pm
You don't need to push the wiring block out the back. Just remove the whole cage and the wiring will come with it. It must be held in at the back with another method. The wires wont be holding it that tightly.
You will NEVER get your new head unit to fit WITHOUT first removing the blaupunkt cage.
Try to run your hand behind the cage (first pull all the wires out the way) and see if you can feel a nut and bolt in the centre of the back panel. I've never seen one bolted there but it's possible.
redchurch
Post Mon Aug 13, 2007 10:04 pm
I've had a go at removing the cage again with no luck. The stereo works fine which is good, I was expecting to have to buy extra odd adaptors with the car being so old.
I've got a mechanic coming around to fix my jeep tomorrow so i'll get him to have a look, probally something simple.
Thanks for all the help!!
grantfk10
Post Mon Aug 13, 2007 10:35 pm
Ok, keep us posted, hope you get it sorted mate! :wink:
redchurch
Post Tue Aug 14, 2007 7:54 pm
Right, mostly sorted now. Got the old cage out today by being rough with it, bent it up and pulled it out. My hazard warning switch poped out with it as well!
The cd player fits in fine now, all seems to work - i'm impressed. £60 with cd/mp3/usb/sd card.
Cheers for all the help!
