how can you tell if you have a power steering rack fitted
- Brianmoooore
Simple bolt on job using all the bits from any E30 donor with the same series engine.
as brian says
very easy swap did my tech 1 in just over an hour incl jacking up car etc
make sure you get everything from the pas car pump bracket etc and the steering coupling
www.oldskoolfantasy.co.uk
think all facelifts are pas
a lot of preface are too but some people opted for non pas
but then i got older and needed the pas cos im lazy
- Brianmoooore
I have (had) two facelift 2 door 318s without PAS as well.
My Glass's guide says standard from Sept '88.
