My M42 engine is knocking on 196,000 miles now and I'm going to have to do something in the next few months.
I'm still considering a rebuild (rebore, new rings, bearing shells, seals etc).
Another option which appeals to me is to fit an [edit]M44[/edit] engine, ideally the 1.9 unit.
A 50,000mile unit from, say, a crashed E36 would be ideal.
Is there any general info on this? I assume that the blocks are the same and the rest similar. I also assume that the ECU and engine loom will have to swapped over.
M44 into E30 318iS
tomstickland
Dan318-is
m43 is a single cam tom!! Dont do it!
Try an ind an m44 instead, quite a bit of work for it to go in though; speak to tim mate hes well informed on it.
tomstickland
Sorry, my mistake, I meant the 16v engine from the E36 318.
Thanks to another thread
316I M43 = 1596CC - 75 KW
318I M43 = 1796CC - 85 KW
318TI M44 = 1895CC - 103 KW
Dan318-is
M44 1.9 is the one to for mate. Loom, ecu etc all have to be changed & a whole host of other stuff, there is no fabrication etc needed though i don't think just swapping of parts.
tomstickland
I've just been looking on some other threads and it looks like a reasonably simple mix and match job.
I've been a bit torn between "keeping it original" and the option of a more modern engine. I love the M42 for its buzzy fun, but the the M44's are newer. I expect it to have similar performance; maybe a tiny bit more mid range from the overbore.
Dan318-is
M44 is the way to go mate. Newer, probably quieter and more torque from the factory. No brainer & definatly worth it mate.
fozzymandeus
M44 doesnt have the M42 profile gasket design flaw either... and other than that is a very similar engine, in terms of rev-happiness and engine note.
tomstickland
Looks good then.
Thanks!
Thanks!
RickDangerous
Deffo go with M44. Way more torque, smoother and quiter.
Just need engine and engine loom. Don't use the E36/Z3 ECU as it will have all the EWS security in it. Have your M42 ECU re-mapped to take advantage of the extra 100cc's and it will run fine!
jmc330i
And the M42 sump etc I would guess???RickDangerous wrote:Just need engine and engine loom.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
