Oil leak from head gasket? - 325i
chippenham_touring
Post Sat Jul 28, 2007 6:36 pm
Engine is losing oil from the top of the engine, not sure wether it is the rocker cover gasket or the head gasket.
There are stains on the rocker cover, but the head itself seems clean. Not sure if this is due to the heat burning the oil off in that area.
Block is covered with oil.
Any ideas?
zimmerbimmer1
BMW Parts Meister
Post Sat Jul 28, 2007 6:56 pm
check the front camshaft oil seal.
where on the block is the oil stains
jcjdavis1
Post Sat Jul 28, 2007 7:46 pm
zimmerbimmer1 wrote:check the front camshaft oil seal.
Hi If it is the cam oil seal is it easy to change. (not trying to steal thread)have similar prob.
stonesie
Post Sat Jul 28, 2007 9:35 pm
If it is the front cam oil seal you will need the cambelt off to get at it (and the pully) so its best to change the belt and idler/tensioner pullys, then it turns into a ''may-as-well'' job... You may-as-well change the water pump and flush the coolant system out while your in there, then change the alternator and pas belts.
It goes on and on :chuckle:
jcjdavis1
Post Sat Jul 28, 2007 9:45 pm
Hi After swapping head plus all the usual I have a small amount of oil and was told it was probably cam.oil seal.
Post Sun Jul 29, 2007 8:39 am
Another common one on old heads is the rocker shaft u shaped plugs. They go hard and leak like sieves.
chippenham_touring
Post Sun Jul 29, 2007 5:41 pm
It has been leaking for a while, so it is difficult to tell but it seems worst at the sides of the block. Where are the u shaped plugs?
Post Sun Jul 29, 2007 8:07 pm
On the ends. They seal the u shaped apertures where you drive the rocker shafts out.
Sounds like just cam cover gasket to me. They aint that dear. Stick a new one on see if it cures it
zimmerbimmer1
BMW Parts Meister
The U shape plugs fit at either end of the rocker shafts.
Try steam cleaning engine and watch were the oil comes from
chippenham_touring
Post Mon Sep 03, 2007 1:19 pm
I can't find them on the ETK, any idea what the p/n is?
jcjdavis1
Post Mon Sep 03, 2007 1:41 pm
Hi Plug part no.B11.1.264.519 Price for 4 £3.62 for a 320i
PS After changing I am still getting oil down the o/s front corner of engine,looks like cam oil seal next.
