Hi does anyone know where I can get hold of the red insert strips for the front and back bumpers on my M3?
Red strip for my M3 bumpers
Darylzimm3
Try your local sign makers, they will have loads of differant shades of red vinyl, just match it up and get them to cut it to width and lengh you require... job done
ian332isport
As far as I know, it's a dealer only job.m3will wrote:Hi does anyone know where I can get hold of the red insert strips for the front and back bumpers on my M3?
51 14 2 233 023 - Rear (approx Ԛ£29)
51 14 2 233 024 - Front centre (approx Ԛ£8 )
51 14 2 233 025 - Front left (approx Ԛ£10)
51 14 2 233 026 - Front right (approx Ԛ£10)
These red trims are spec'ed for Sport Evo models only, so may require a chassis number before they will order them.
Ian.
m3will
Cheers thats a bit expensive though does anywhere do reproduction ones
M3Imy
I got original ones form C3 in south london for about Ԛ£40ish or maybe a bit less than that. 3m make the strips. You can buy some 3m tape that is exactly the same but is not cut to fit exactly. the width is the same though.
m3will
When you say 3m tape do you mean normal electricians tape or is a special one? If so where could I get it
thanks
thanks
Daryll
3m is a manufacturer of all manner of adhesive tapes...available from numerous sources.
Give http://www.suretech.co.uk/ a try, they seem quite reasonable. Tell them what sizes you want and send them a colour and they'll even pre cut it for you.
@e30_daryll
cuk325
hiya mate let me know how thick you need it & ill sort you some out, id use replective on there as it would look sweet
