gauges
shedrool83
- Kos
- Contact:
i had a water temp gauge, oil temp and voltage
www.pukardesigns.com
IG Pukar.Designs
IG Pukar.Designs
I'd have oil pressure, oil temp and water temp(if you don't trust you bmw gauge). Otherwise swap that for volts. So pretty much what you said
Would definatly have oil pressure though. You can kind of tell oil temperature from oil pressure too.
shedrool83
If you're feeling fancy you could go for a diff fluid temp guage, I was in an E36 M3 the other day and the bloke had fitted diff and gearbox temp guages, very interesting to see what was goign on in there.
Oil pressure is the most important one to go for, been meaning to fit my guages for ages, but they are still sitting here gathering dust.
- Kos
- Contact:
oil tep and voltage are easy enoughshedrool83 wrote:How easy are the oil temp oil pressure and volts to install?
oil presure, there is a oil presure swith on every e30 and you could take it from there
IG Pukar.Designs
IG Pukar.Designs
shedrool83
Seen these type but maybe a bit to modern for an e30 think the needle one would look better but not made my mind up yet
http://cgi.ebay.co.uk/2-Oil-Temp-Digita ... dZViewItem
shedrool83
- Kos
- Contact:
no worries, i'll help you outshedrool83 wrote:Might need a low down on the install when the time comes.Kos wrote:oil tep and voltage are easy enoughshedrool83 wrote:How easy are the oil temp oil pressure and volts to install?
IG Pukar.Designs
IG Pukar.Designs
- NeilMukerji
- Contact:
This sounds interesting - has anyone got any pictures of these installed? Where do they go - in lieu of the centre air vents, or behind the ash tray, or...?
- Kos
- Contact:
have a look on the link here, i'm getting them made very very soonNeilMukerji wrote:This sounds interesting - has anyone got any pictures of these installed? Where do they go - in lieu of the centre air vents, or behind the ash tray, or...?
http://www.e30zone.net/modules.php?name ... 84&start=0
IG Pukar.Designs
IG Pukar.Designs
[/b]
