Specs:
1,500 WATTS TOTAL OUTPUT per sub
# 500 watts RMS per sub
# Frequency Response: 23 Hz - 500 Hz
# Sensitivity: 87 dB
# Dual 2 Ohm Voice Coil Version
# Mounting Depth: 8"
# Sealed Box Volume: 0.7 - 1.0 cubic ft
# Ported Box Volume: 0.75 - 1.75 cubic ft
# Kevlar re-enforced Pulp Fiber Cone Assembly
# Santo-prene Rubber surround material stops un-wanted vibration noises and ensure clean sound
# Dual Voice Coil Design
# Cast Aluminum Frame
# This sub is vented and transfers the heat out of the sub so it stays cool at all times
# Concealed Mounting Gasket System Frequency Response: 24 Hz - 500 Hz
Next on the list is an enlosure to house the subwoofers! i dont want to go down the DIY route as i havnt a clue how and if i try, i would make a complete and utter mess!!
I found this ready made enclosure which is 12" Twin Bass Box 2 x 1.0 Cubic.Ft, Clicky
Do i go for sealed or ported? (whats the difference?)
Next is Amplifiers!
Any recommendations?
Should i power 2 subs off a one mono amp? (or 2 mono amps?
Or off a 2 channel amp?
Do i go for highest watts i can afford and just turn it down so not to blow the subs
or go according to the power the subs can handle?
Any brands in particular!? I havent really got a price limit!!
I have just been given a 4 channel kenwood amp from my bro which i will use to power the front components and rear speakers.
Sound proofing...
Does it make a difference?
what do i go for, is dynomat extreme the best?
will be looking forward your opinions!
Thanks you!
Saq.
