OBC Immobiliser
Widge
Post Fri Apr 22, 2005 11:13 pm
OK so I know how the OBC immobiliser works, (and it was factory fitted so it does work) But when I enter the wrong code a couple of times there is just a relay clicking noise from under the dash. Sould a horn be sounding? and if so which one?
Cheers :D
cros
Post Fri Apr 22, 2005 11:58 pm
The OBC has it's own horn for when you get the wrong code.
It's behind a metal plate up above the left brake duct (underside of where the ABS pump is).
It's run off a switched ground from the OBC relay box (brown/yellow through the bulkhead) and gets a permanent 12v via red/black or red/white from fuse 27.
Should be enough to debug & fix! HTH.
Widge
Post Sat Apr 23, 2005 10:36 am
Cheers mate :)
I should think the horn or the wire is just buggered from not being used
acc
Post Sat Apr 23, 2005 6:58 pm
CAN YOU HELP DIFFERENT ISSUE I HAVE TWO WIRES BROWN AND BLUE FOR TEMPERATURE ON BMW 325I SPOERT 1991 H -THE TEMPERATURE SENSOR WIRES ARE BLUE THERE ARE 2 IS THIS CORRECT
cros
Post Sat Apr 23, 2005 7:53 pm
The temperature sensor is just a resistor: polarity isn't important.
If you're sure you have the correct wires on the OBC side (displayed temp goes from freezing to boiling when the two wires are shorted), just connect them any way you like to the sensor.
