2.7 Oil Cooler?
baur320
Post Sat Jun 23, 2007 1:02 pm
Car's getting early 2.0 swapped for a 2.7. It didn't have an oil cooler fitted, as I'm guessing 2.5s do, so i was thinking about doing it myself when the car comes back.
It's away at the garage waiting finishing, so i can't see it at the minute.
Question is, apart from the cooler itself and the pipes, what else is involved with fitting? I'm guessing oil filter head, unless the 2.7 is compatable.
Anyone any clues?
Thanks,
Mick
billgatese30
Post Sat Jun 23, 2007 1:21 pm
looking at oem there is a diffenerce in the pipes and cooler between the early and late 325 engine, not sure whether you'd need the one to match the car to get the mounting position right (early type) or the one to match the engine (late type) to get the pipes right.
baur320
Post Sat Jun 23, 2007 2:41 pm
Thanks for that Chris.
I've got my eye on a cooler out of an '88 sport that Ian Lessiter's got up for sale. The e28 was also an 88.....
Mick
chu346
Post Sat Jun 23, 2007 3:53 pm
Why do you feel you need an oil cooler?
They just leak anyway.
baur320
Post Sat Jun 23, 2007 3:55 pm
Just presumed as the engine's bigger.......
Dont 2.5s have them?
chu346
Post Sat Jun 23, 2007 4:03 pm
As the engines bigger what???
I took mine off and have no problems.
If your going turbo or on the track fit one otherwise I don't see the point.
baur320
Post Sat Jun 23, 2007 4:18 pm
baur320 wrote: Car's getting early 2.0 swapped for a 2.7.
chu346
Post Sat Jun 23, 2007 4:26 pm
So.....
Like I said unless your going turbo where oil temps will be higher from the turbo or use the car on the track I don't see the point unless you live in a hot country.
oakey
Post Sat Jun 23, 2007 5:15 pm
Why are they fitted to 325i's then matey?.... if you dont need one?
There must be some benefit
chu346
Post Sat Jun 23, 2007 5:40 pm
Alot of people me include have bypassed the coolant lines that go to the throttlebody because they are only really needed in cold countries. This is the opposite.
Demlotcrew
Post Sat Jun 23, 2007 7:07 pm
Sorry but an oil cooler is a must for any car and why you would want to get rid of it is beyond me.
:eek:
chu346
Post Sat Jun 23, 2007 7:21 pm
So why don't all cars have them?
Jon_Bmw
Dangerous when thinking
Post Sat Jun 23, 2007 7:24 pm
Demlotcrew wrote:Sorry but an oil cooler is a must for any car and why you would want to get rid of it is beyond me.
:eek:
I agree, wouldn't like to know what oil temperature mine would run without its oil cooler.
Jon_Bmw
Post Sat Jun 23, 2007 7:27 pm
chu346 wrote:So why don't all cars have them?
If you are building a 2.7 the chances are you like a spirited drive every now and then so to dump the oil cooler would be silly imo.
chu346
Post Sat Jun 23, 2007 8:38 pm
I'm not saying dump it if you have it and it's not leaking. My one was leaking, I bought a replacement off here and some idiot sold me one for a different car so decided to dump them both. Not had any problems and was recommend by many on here to dump it.
BTW not that it makes much difference mine is a 2.7 aswell.
oakey
Post Sat Jun 23, 2007 8:46 pm
when oil gets too hot it breaks down causing possible damage to the engine over time no? I can see the oil cooler bieng useful for this reason.
^if I were in your position though chu I would probably have done the same
Morat
Post Sat Jun 23, 2007 10:32 pm
Maybe you could fit an oil temp gauge instead and keep an eye on the situation?
Post Sat Jun 23, 2007 10:59 pm
Oil technology has advanced massively since the M20B25 was introduced, and I wouldn't worry in the slightest about the lack of an oil cooler for road use.
None of the later M5x series of engines have an oil cooler.
Post Sat Jun 23, 2007 11:14 pm
Thats right Brian but I do intend on fitting a cooler to mine at some point to benefit the overall engine cooling, just sorting out a deal involving an Alpina B3 3.2 oil filter housing with take off for cooler lines at the moment, winkeye
Andyboy
Alpina Colada
Post Thu Jun 28, 2007 1:32 pm
Brianmoooore wrote:Oil technology has advanced massively since the M20B25 was introduced, and I wouldn't worry in the slightest about the lack of an oil cooler for road use.
Exactly. A 318iS for example works much harder and they don't have one. If it's there and not leaking then fine but to do without it and use a good quality semi synth would be okay. If you drive down the motorway at 6000 rpm on a very hot day then yes, then an old skool 20/50 oil will get hot.
