Any advice would be appreciated!
How can i tell if my car has an LSD
bmw-mad
Ok i have a e30 320i se 1990. i am not sure if the car has an lsd how can i find out. someone has told me if i jack it up and spin the wheels and if they turn the opposite to each other its an Lsd is this true or a load of bull
march109
bull, why would they turn opposite to each other,
However I'm not entirely sure how to tell with this method, I thought the wheel you turn would spin once for every 4 revolutions of the other wheel, but don't qoute me on that either.
The only way I know to check is find find some dry hard concrete/tarmaced ground, and floor it.... if you leave a number 11 in rubber on the floor you have a LSD.
eko
- Old timer
If you jack it up and rotate one wheel and the other rotates the same way then it is an LSD,if they rotate opposite ways its an open diff!
Or you could just do what March said,hold the revs at 3k and drop the clutch,number 1 is shite,number 11 rocks
march109
^^^^ what he said!
Number 11 FTW!
Number 11 FTW!
dave525
find the small metal tag held on the back cover by one of the bolts.clean off the rust,doesnt matter if it is really rusty should still clean up. if it says s3.19 the s means its an lsd.the other number is the ratio.no s = no lsd
bmw-mad
Ok thanks guys will get the car fired up tommorow and try the number 11
Davenotouring
Or jack one side up, if it is stiff to turn. It's probably an LSD. (OR a sticky caliper!) haha
BMW 328i Cab - Daily Slag
- Homo Hair
you can get 11 with an open diff tho..
harry_p
a less agressive way is to park with one rear wheel on something slippery (wet grass verge is ideal) the other on nice grippy tarmac.
pull away quite quickly, if the revs rise but youre not moving very fast it's not an lsd. if it is an lsd it should lock up and you'll pull away fairly normally.
or, jack it up under the diff, if the wheels spin freely, and turn in oposite ways it's an open diff. if theyre hard to turn and / or turn the same way as each other then it's an lsd.
cheers,
harry
harry
snoops
- Major Helmet
best way is to check the tag as you could have a shagged LSD that behaves like and open diff...
SamE30
Lay down some rubber my son!!
'88 DiamondSchwartz 325i tourer
SOLD!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
bmw-mad
Thanks for the help guys but it was an open diff!
Endless325
What method did you use to find out
bmw-mad
Burn't some rubberEndless325 wrote:What method did you use to find out
JohnnyThunders
If your car has LSD it should look like this.
lol soz i know its an old one.
bmw-mad
my car has Definitely not got an lsd if its supposed to look like thatJohnnyThunders wrote:If your car has LSD it should look like this.
