Fitting Bucket seats..
- Homo Hair
Using sidemounts etc.. Can you use original bolts holes?
Karan
yes u can thats the best place and only place id mount mine, u may have to mod up the brackets to suit but it shouldnt be too hard with some plates welded top extend the bottom bit inwwards
JimmyC
If you buy using the deal I set up with Cobra they do an e30 sidemount
Weeman
Karan is right, I had a nightmare trying to fit some OMP sidemount seats into my e30, rallynuts and OMP themselves said the subframes they sold would be fine, which they were for alignment, but the seats were almost touching the roof. the sidemounts almost fit as they are, but there would be next to nothing between the side of the mount and the hole that would be drilled through it, therefore I got a piece of aluminium the same thickness but twice the width, and longer by 5cms at each end of the mount (to allow for some movement back and forwards) Which will be welded onto the bottom of the mount by an ally welder. This should allow plenty of room to drill the holes safely, then the seat will bolt straight onto the floor, allowing for a bit of adjustment using the holes in the sidemount.
alan1272
i have a set of base mounted cobra monaco's, i don't suppose anyone has any pics of base mounts fitted in an e30?
