Sheared brake nipples
klu99apm
Sat May 26, 2007 3:40 pm
Before I started replacing all the brake lines at the back of the car I thought I'd check the bleed nipples undo.
Well they didn't! And they paid the ultimate sacrifice for their stuborness (actually I didn't think I applied that much force, especially the second time)
Can I drill the old ones out and replace or would it be easier just to replace both the rear calipers with ones that have functioning nipples?
gareth
Sat May 26, 2007 10:26 pm
i did just this earlier! luckily i had a spare caliper in the garage.
that one needed to be stripped though as the bleed nipple drilling was blocked!!! :mad:
Theo
Sat May 26, 2007 10:30 pm
Oh dearm is there nothing left of the bleed nipple?
Molegrips are great for stubborn/rounded/gay bleed nipples, but if there's nothing left of them, then it's too late!
Sat May 26, 2007 10:32 pm
Shouldn't need drilling as there's already a hole down the middle.
Won't be able to use a very big extractor though. Day or two's treatment with WD40 and you may be lucky, but I doubt it.
smithy318i
Sat May 26, 2007 10:38 pm
use heat next time... lots of it. (you cant beat a blowlamp and a pair of molegrips)
You can drill the hole a bit bigger, then use a stud extractor tool.
evodan
Sat May 26, 2007 10:54 pm
If theres anything left sticking out then I've seen it done by welding a similar sized bolt onto the stub. U can then get a spanner on it plus the heat will free it off, does work.
gareth
Sat May 26, 2007 10:58 pm
mine snapped of flush. :?
why on earth did BMW use M7 threads? the only other time i've EVER seen M7 is on pug 205 strut top nute.
