Bentley manual says you can get eccentric upper strut mount to change camber of front suspension. Part no. 31 33 1 124 547. Depending which way you fit it, camber changes + or - 30' (1/2 inch)
I have fitted Spax 40mm lowered suspension all round, and am about to fit M3 solid offset control arm bushes to reduce inner tyre edge scrub. Would changing the camber geometry also help with this much lowered suspension, i.e. the tyres obviously 'toe-in' more when lowered 40 mm, so would changing camber put this right?
Any advice gratefully received!! (Anyone know the costs/availability of these ecc. strut mounts?)
Eccentric upper strut mount
Treeman612
Treeman612
Hi, guys, more info on eccentric strut mounts - they are available from BMW Germany, a new batch is due in to them end of April. If anyone wants to fit them, these are part numbers and current exc. vat prices:
Support bracket - 31 331 139 48411- 2 needed, (one each side!) Ԛ£54.90 each
New bolts - 31 331 092 886- 6 needed, (3 each side) - Ԛ£0.51 each
New caps - 31 31 1139 453 - 2 needed - Ԛ£0.60
psychochild187
ive got the top mounts on mine from mosley motor sport !
i got them off a friend fro 30 Ԛ£ but i think he paid 50ish for them both!
u can see the neg camber
ive also got the 40 mm spax psy kit
u cant use the caps for the reason the adjuster on the top of the strut is too long and it wont cover it
i love this mod and i need the m3 bush for the wishbone next if knew where to get them!
- Homo Hair
Mosley only list the adjustable ones on their site.. Ԛ£298 per pair!!!
psychochild187
hmmm
i know my friend got them from there !
there the two way adjustable ones
they have 6 six holes to put them in with!
u need to put new bolts in , i had the 6 off my old mounts loose my friend took them out,
but i had to file the holes in the new top mounts out abit to push the bolts in ,
they just must not list everything on the site
