Stock 318is's: distance from wheel arc to wheel hub?
frankiez
Mon May 07, 2007 7:30 pm
Can someone post the measurement of the distance between wheel arc to wheel hub of a stock 318is( 205/55/15).
My register file says it is in the front 310mm and in the back 330mm.
The car is equipped with a lowering kit and 215/40/16 tyres which have smaller diameter than original 205/55/15.
I'm trying desperately sorten out wether 60/40 spring set wuold give same result since I have to replace old suspension set.
Please, HELP NEWBIE!!
