E30 Sunroof Conversion
daniele30
Fri May 04, 2007 5:03 pm
hie bro,
i having an e30 with manual sun roof, i would like to ask wherther can i be convert to electric sun roof ?? what parts do i need for the conversion ??? complete electric roof or just the motor & wiring ???
thanks guyss
Chris-W
Fri May 04, 2007 5:33 pm
Wiring loom, switch, headlining panel, motor, mounting plate complete with cable guide tubes.
Let me know if you want a full kit as I have them available.
Cheers,
Chris
R9
Fri May 04, 2007 5:43 pm
How difficult to actually fit - is it very fiiddly?
Chris-W
Fri May 04, 2007 5:51 pm
Not really a bad job. Less fiddly than you would presume.
R9
Fri May 04, 2007 5:53 pm
Can you jot down the procedure real quick?
I'm sure daniele30 would benefit too.
Cheers.
Chris-W
Fri May 04, 2007 6:04 pm
Might not be 100% comprehensive, but it gives you the general procedure:
- Open sunroof
- Remove front air-spoiler
- Remove strip securing headlining panel to sunroof aperture
- Unbolt ends of cable guides from body
- Unbolt manual mechanism and withdraw the from the cables
- Close the sunroof
- Feed cables into guide tubes of new mechanism (which needs to be in the fully closed position)
- Run loom down LH A pillar to the accessory socket above the glovebox
- Bolt it all back together, using the new headlining panel
Just a general warning - there are LOTS of nasty sharp bits in sunroofs which WILL cut you!
R9
Fri May 04, 2007 6:05 pm
Awesome. Cheers.
daniele30
Fri Aug 03, 2007 2:40 pm
yup i've remove the sun roof for cleaning & re-spray back.
by reading is really hard to remove the sun roof, i bet u didn't do it after reading this.... do u ???
M16
Mon Aug 06, 2007 6:42 pm
Just happened upon this.
I'm going to do this this WE (can document for the zone) just one question.
Where does that huge motor possibly fit in the roofskin? Or does it go where the manual winder goes?
