which will stick out more
E3OBM
Sat Apr 14, 2007 8:54 pm
i need to know if my 9jx16 et 15 will stick out more or will my 8jx16 et11 .
i want to put 5x120 alloys on my cab, can you buy adaptors to change from 4 stud to 5 stud, how much extra will they stick out with the adaptors
where can i buy the adaptors from?
thanks Ray
maxfield
Sat Apr 14, 2007 8:59 pm
The 9s will stick out more.
yes they do adaptors for that.
E3OBM
Sat Apr 14, 2007 9:04 pm
maxfield wrote:The 9s will stick out more.
i got 9s on at the moment and i just get away with 60ml drop with the arches grinded, do you think if i put the adaptors ona put the 8s on i will get away with them touching.
i had done a 5 stud conversion on my cab and i put the 8s on but they stuck out miles, i think the reason being they stuck out that much was because i used e36 conversion setup which come out an inch anyway,
so do you think the adaptor is the best thing if i put my e30 suspension back in, where do you buy the adaptors from
harry_p
9s will stick out approx 8.5 mm more than the 8s. their higher offset means the centres will sit further inwards, but the extra 1/2in of the width on the outside edge means overall they will sit 12.5mm - 4mm = 8.5mm further towards the arch.
i think most pcd converting adaptors need to be 20mm thick as a minimum
cheers,
harry
maxfield
Sat Apr 14, 2007 9:05 pm
Retro_wheels can supply you with them
the 9s will stick out more
E3OBM
Sat Apr 14, 2007 9:08 pm
harry_p wrote:9s will stick out approx 8.5 mm more than the 8s. their higher offset means the centres will sit further inwards, but the extra 1/2in of the width on the outside edge means overall they will sit 12.5mm - 4mm = 8.5mm further towards the arch.
your good with figures aint you winkeye
so would you agree with maxfield, i need to get in touch with reto-wheels now
tobias
Sat Apr 14, 2007 10:15 pm
OBs
Sat Apr 14, 2007 10:17 pm
:ttiwwp:
Of both sets winkeye
