bypass
jordano
Post Tue Apr 12, 2005 11:04 am
Just a quick one a couple of the rear outputs from my active crossover are not working they both feed seperate speakers is there anyway i can bypass the crossover and go straight to the anps? i thought a y phono would work but im not sure J.
placey
Post Wed Apr 13, 2005 9:53 am
yes a y lead will work - but you'll halve the music signal strength after the split. try it - it might be ok - but you might have to invest in a line driver, then you'll have to consider whether that's cost effective or whether to replace/repair the active x-over.
amp settings will need tweaking - probably something like gain increase and filter applied if not already on.
paul
i saw a doctor and she gave me some pills....
