INDIVIDUAL COIL PACKS FOR M30
oze30
Post Thu Mar 22, 2007 8:10 pm
Heya,
just wondering, If I wanted to go with 6 coil packs, what are the advantages/disadvantages of it?
How complicated would it be?
Would m50 coil packs work?
Ant
Retired Team Member
Retired Team Member
Post Thu Mar 22, 2007 8:14 pm
COP setup requires a cam position signal to phaze them correctly, and of course you'd need 6 coil driver outputs on the ECU
TBH, a wasted setup is easier to implement, and achieves the same goals.
HTH
oze30
Post Thu Mar 22, 2007 8:21 pm
Ant wrote:COP setup requires a cam position signal to phaze them correctly, and of course you'd need 6 coil driver outputs on the ECU
HTH
WTF??? that kinda made no sense to me! I need a cam sensor, and a different ecu???
What would the benefits be?
Andy335Touring
Post Thu Mar 22, 2007 9:09 pm
COP = coil on plug
Like Ant said....
You can get the coil packs from V6 Omega's or Scorpio 24v.
Basically a wasted spark set up fires two cylinders at once, one ignites the fuel mixture on one piston thats comming up on the compression stroke, the other piston that is fired(sparked) is on the exhaust stroke so the spark does nothing or is wasted.
The COP set up needs the cam sensor to tell the ECU which plug needs firing at the right time.
oze30
Post Thu Mar 22, 2007 9:26 pm
right. So itd be a waste of time if I got m50 coilpacks?
What else would be needed if I get the omega or scorpio set up?
Ant
Retired Team Member
Retired Team Member
Post Thu Mar 22, 2007 9:31 pm
Ok, M30 as std has a single coil and dizzy to distribute the sparks to the correct cyls @ the correct time.
To revise this, and use the omega/wasted setup, you need an ECU ( aftermarket ) with provision for multiple coils, then you may add the coilpack setup.
no way around it dude, the stock ECU cant be modded to add the req outputs.
M5 3.8 runs COP but the cost of the parts would be telephone numbers.
SPADGE
Post Thu Mar 22, 2007 9:34 pm
Col - I have a question for you. Why do you want to run coil packs????
Its going to gain you little on your stock M30 lump :?
Andy335Touring
Post Thu Mar 22, 2007 9:37 pm
oze30 wrote:right. So itd be a waste of time if I got m50 coilpacks?
No real benefit, more work
Assuming you already planned using a MS ECU nothing extra apart from the wiring and make sure the ECU is configured to run wasted spark. One positive feed and three negative ignition drivers from the ECU.
The only slight thing you will have to play with is routing the HT leeds, depending where you mount the coil pack.
[edit, too slow/making coffee]
oze30
Post Thu Mar 22, 2007 9:38 pm
Someone said that coilpacks and MS would be better on fuel?
Andy335Touring
Post Thu Mar 22, 2007 9:40 pm
SPADGE wrote:Col - I have a question for you. Why do you want to run coil packs????
Too lose the dizzy cap/rotor arm, a bit of a weak point/old tech
oze30
Post Thu Mar 22, 2007 9:45 pm
but just thinking outside the square.. The more parts and stuff I can do here, the cheaper.. in oz, that's not possible..
SPADGE
Post Thu Mar 22, 2007 9:52 pm
Yes Andy i can see that being an advantage on perhaps a blown or high comp tuned engine but not a stock one!
I guess there would be a slight gain as the cam wouldn't have to carry the weight of turning the rotor though :P
Col try answering your phone for once btw :?
oze30
Post Thu Mar 22, 2007 9:53 pm
Who says it's not going to be forced??? winkeye
Ant
Retired Team Member
Retired Team Member
Wasted has a few benifits, no mechanical loss on the ignition = better spark, smooth like never before was my 1st impression when I added wasted to my M20B25T
Allegedly it reduces the piston temp when dry firing and should benifit the emissions, not that thats a major consideration
Hmm, :idea: Idea, wonder if I can resubmit my car to be classified under the newer emissions regs, and get cheaper tax :lol:
SPADGE
Post Thu Mar 22, 2007 9:54 pm
I'll wager that car never goes from these shores :D
Andy335Touring
Post Thu Mar 22, 2007 10:04 pm
Do the prices on here seem good ?
Scorpio 24v coil pack for £50 plus VAT
http://www.ignitioncarparts.co.uk/ignitioncoil.aspx
Andyboy
Alpina Colada
Post Sun Mar 25, 2007 4:55 pm
Andy335Touring wrote:Do the prices on here seem good ?
I'd want a 24v Scorpio for £50 all in. Your local branch of Council Motors should have one in stock.
As for M30 caps and rotors - I've just replaced the 263'000 miles 1989 original on my beast.
m-dtech
Unapproved Trader caution
Post Sun Mar 25, 2007 6:45 pm
m50 has individual coil packs.
im hoping to use megasquirt on it :D
