E28 and E34 M30 lumps
Post Sun Mar 18, 2007 11:53 am
A mate is getting me involved in the restoration of his E28 525i, ive just about got it in his head that fitting any engine less than a 3.5 M30 is a waste of time :)
What I need to know is would the E34 M30 be a better choise? Younger engine etc, I know the M30 converters favour these for the E30, is it because of mounting points? Wiring loom?
Any help would be appreciated 8)
DRIFTBOY
Post Mon Mar 19, 2007 12:59 am
It is mainly due to the shape of the sump and oil pick-up pipe - the E28 M30 is the wrong shape for the E30 cross-member.
The E28 also has it's crank sensor in the top of gearbox and the E34 one is on the front on the timing cover.
One or more of the cooling / heater hoses are different as well.
I think these problems can be overcome but it's not worth the hassle when the correct engine for the application is cheaply available still.
I reckon he'll be better off with an E28 M30 engine.
Or going out and buying an E28 M535i ! winkeye :cool:
Martin.
Post Mon Mar 19, 2007 9:57 pm
Funnily enough I also know of an M535i lump for sale! 8)
gareth
Post Mon Mar 19, 2007 11:36 pm
earlier lumps are higher compression too. go for an early one. :D
DRIFTBOY
Post Tue Mar 20, 2007 12:21 am
Don't they also have smaller valves or ports or something though that makes the early and late ones near enough the same power ?
I could be wrong, but I thought E28 and E34 (non cat) 535i were both rated at around 217 bhp.
Martin.
bryang
Post Tue Mar 20, 2007 1:41 pm
I believe the E28 M30 lump is rated at 218BHP and all E34 lumps 211BHP due to changes to allow for running on un- leaded fuel when the E34 was introduced back in 1988...16 years later mine kicks out 206BHP so not too bad a loss over the years..
