A friend of mine has just bought an M plate 316 compact. As much as I hate them, I like him so said I;d ask for some advice.
His windows wont go down, they're electric.
His brake lights dont work when the lights are on...
any ideas?
e36 compact problems.. experts needed.
munky30
- 100% Pure Council
kam-325i
1, Windows - Check the breaker switch/Fuse.
2, Does it have a seperate "brake light bulb" or combined "stop and tail" bulb ?
dazleeds
- old skool raver
all e36 windows have problems
not sure what fecks up but i havent seen many with fully operational windows
always start with the obvious tho
fuses/relays/switches/connections/1 touch relay if fitted
www.oldskoolfantasy.co.uk
Andyboy
- Alpina Colada
On an 1994 M plater it might be one touch driver's window only and the relay is actually part of the motor which unbolts. But the fact that both windows are down suggest a fuse/and/or power supply problem.
But I'm pretty sure that by the time the Compact came out they'd ditched that idea and put the relay somewhere else. I'll have a think.......
dazleeds
- old skool raver
i seem to remember it being near the glovebox near the abs ecu
Damn i admitted remembering that
brake light sounds like some sort of short in the circuit
call Brian
call Brian
munky30
- 100% Pure Council
Yeah I thought it sounded like a short/bad earth as they work when the main lights are off... I think they are separate bulbs as opposed to all in one twin element ones.
Will pass all this on but keep it coming, I'll get more info off him tomoro as I only saw him for 5 minutes tonight so didnt get much more than a bit of a rant about his 'shitty e36' (his words not mine)...
I get cheap parts off this guy so like to help him out in return when i can
