Panel filter or induction kit
Conrad
Post Sun Mar 11, 2007 10:55 pm
I have a 318is, what's the best induction mod performance wise? A replacement filter in the standard airbox, or an induction kit?
tib996
Post Sun Mar 11, 2007 11:16 pm
k+n cone filter every time
200sx s13 currently undergoing vg30dett swap
bmw 320i
audi 90 sport
liam012
Post Sun Mar 11, 2007 11:23 pm
K and N bolted on to your AFM will more likely loose you power and torque.
stock is best at present (i think)
unless you prefer sound?
to answer your question i would go panel filter.
flame suit on
Omi
Witty custom rank.
Post Sun Mar 11, 2007 11:45 pm
The airbox is a good design and actually provides cold air, which a cone will not.
Panel filter every time.
Someone did a few tests with a leaf blower a while ago, showing the stock filter is actually better than the K&N too.
...or is it?
Post Sun Mar 11, 2007 11:58 pm
A completely standard set up with a clean OE filter is the best set up. K&N panel filter won't lose any power, but it's not to hot on the filtering bit.
reggid
Post Mon Mar 12, 2007 1:27 am
Omi wrote:The airbox is a good design and actually provides cold air, which a cone will not.
the K&N flows better full stop i did before and after dyno runs with ~7hp across the board but as brianmoooore said the filtering abilities of the K&N Panel Filter are the only question mark.
Conrad
Post Mon Mar 12, 2007 8:06 am
Was this with compared to a clean OE filter?
I find it hard to believe a K&N panel filter can gain you 7HP, more like 1/2 a HP and lots of throttle response in my experience...
Con
Post Mon Mar 12, 2007 8:45 am
reggid wrote:the K&N flows better full stop i did before and after dyno runs with ~7hp across the board
Sorry, this is just not possible. That 7hp was coming from somewhere else!
pnd
Post Fri Mar 16, 2007 3:49 pm
In my experience a k+n panel filter does make the car more responsive than the standard filter but not 7bhp more responsive. Also remember a dirty filter is not as good as a clean one and K+n's need cleaning way more often than the manufacturers state.
