re head gasget
sloppysean
re head gasget ,iv just got my 325i sport cab back from the garage work done head skimed and preasure tested new gasget ,valves done ,ok when iv started the car iv got some condesation , or light smoke from the exhaust its not over heating but the heaters are not hot it have i been had off ,
jcjdavis1
Hi If everything is ok except your heating try bleeding the system.I took off the header tank cap and just kept sqeezing all the pipes including ones going into bulkhead,watching the water level in the header tank and keep filling up coolant.I then started engine and let it get up to temp doing same,you will feel the heaters getting hot,put cap on.I had same heating prob. when I had my head done.I hope this helps.
PS Might be better in the tech section
