Superglue.
gooner1
Out humping Reindeer
Post Sat Mar 10, 2007 6:33 pm
Managed to get some superglue on my bonnet a couple of months back, dont ask :o: , anyone got any tips on removal.
Post Sat Mar 10, 2007 6:40 pm
Thinners
Post Sat Mar 10, 2007 6:42 pm
Carefully :)
gooner1
Post Sat Mar 10, 2007 6:44 pm
Did think of that Dan but was,nt sure. Will be careful, this time :)
munky30
100% Pure Council
Post Sat Mar 10, 2007 6:49 pm
nitromors.
gooner1
Post Sat Mar 10, 2007 6:51 pm
simian wrote:nitromors.
Wouldnt that strip the paint as well mate,? have a can of that somewhere.
bigun
Post Sat Mar 10, 2007 6:52 pm
lol ^^^^
bigun
Post Sat Mar 10, 2007 6:53 pm
gooner it will make your bonnet silver
riklusby
Post Sat Mar 10, 2007 7:01 pm
Check the tube m8 some superglues are water soluble.!
Post Sat Mar 10, 2007 7:03 pm
Im sure you can buy super glue remover come to think of it :?
march109
Post Sat Mar 10, 2007 7:16 pm
Superglue as in the brand is not water soluble, in fact it uses dampness to 'cure'.
fuzzy
He who sleeps with "Gingers"
Post Sat Mar 10, 2007 7:29 pm
best way would be to try to chip it of gently without damaging the paint.if you have good smooth paintwork it might not have got a good 'key' to the surface.
march109
Post Sat Mar 10, 2007 7:36 pm
fuzzy wrote:best way would be to try to chip it of gently without damaging the paint.if you have good smooth paintwork it might not have got a good 'key' to the surface.
agree, just using your nails, not to hard and scratch it off, if you regualy wax your car and keep it clean this wold be the best option and may well just peel off the wax layer.
be prepared tho if the glue has set right on the paint you could end up pulling a patch of paint out.
--alpina--
Post Sun Mar 11, 2007 1:49 am
boiling hot water over that should loosen a little then T-cut it, and your as happy as a gay in bed with two men.
gooner1
Post Sun Mar 11, 2007 7:13 am
--alpina-- wrote:boiling hot water over that should loosen a little then T-cut it, and your as happy as a gay in bed with two men.
Not keen on the simile but might just try that. The boiling water i mean :)
zaust
Zone day release
Post Sun Mar 11, 2007 7:25 am
Hot water is the way.. it works...
M30 Tech 1 Touring on gas.
IB6376CY
Post Sun Mar 11, 2007 7:29 am
try very very very but very carefully to slip a clean razor blade under it, you might just be lucky, but don`t force it.
