Chris-W wrote:If you unbolt the window regulator mechanism from the door you'll be able to slip it off the window mounts.
hiya mate taking the window out is not too hard but puting it back in is very hard lol..
take off your door card then basically u got ten mill nuts bolts and a few ten mill nnuts wat to do is open all of them and then u will have one nut on the motor looen that as much as u can get somebody to hold the window and wind it up or down and the runners willcome out
I think that is what this says, Chris!
