hi
i took my 325i (auto) to a garage to have the engine tuned as it was miss firing when you set off from stand still and also it is giving me poor economy (14 to 15 mpg aound town) i have been told by the garage that the airflow meter is faulty. can this bee true
thanks
WHAT R THE SYMPTOMS OF A FAULTY AIRFLOW METER
Demlotcrew
I think there is more than the AFM at fault.
Andrew
Andrew
- Brianmoooore
To test an AFM, connect a six or nine volt battery across pins 4 and 3, and connect (preferably) an analogue voltmeter across 4 and 2. Oscilloscope is even better.
Move the air flap slowly from fully closed to fully open by hand while watching the meter needle. It should move slowly with no jumping whatsoever.
- **BANNED**
Jassleads,this could just be an air leak around the inlet manifold and its connecting pipework.Check that all manifold fasteners are present and sealing properly,ICV sealed and working?Elbow from T/B to AFM not split?
