I know I dont post much, but I am looking for some geniune advice.....
Has anyone had a metal roof repaired? Mines got a couple of little holes behind the sunroof, and upon taken the roof lining out I have discovered that it would be best to remove the sunroof carrier and get the job done properly, toying with the idea of getting the interior blasted and repainted / proofed. Anyone ever done this? Advice, and buying another car without sunroof isnt an option at moment but I have looked.
Cheers Mark.
Roof repair
swindy
"We aint here for a long time, we're here for a good time."
"Don't take life too seriously, you'll never get out alive."
316eyes
I should think you just need to make sure that you cut back to decent metal so it doesn't comeback.
Have seen a roof distort quite badly when someone did some welding with a gas torch, so worth asking about this!
Repainting the whole interior seems a bit OTT as most of it is covered with trim.
I'm not completely perfect.......there are some bits missing or broken.
But the weather here helps!!!
swindy
Yup but if its blasted it would have no protection and rust like buggery, I meant just a coat an anti rust agent nothing fancy. Thanks for the input though, would be a body shop doing the job, or maybe some zoner that is VERY handy.....
Loony
A lot of the Ford RS people and classic car people have done things like this.You can cut bits out of a roof and weld new panels etc in but as said above it needs to be done by someone who knows what there doing or the roof will warp.For this reason be very very carefull who you use to do this and make sure they have done this before and can do it well.As far as the blasting goes,some people i have spoke to say dont do this as it thins the metal a bit in places and recomend acid dips now but that would mean a full strip of the car and its costly.If it is just light surface rust in some places i would sand it down treat and re paint.
