what size are oil cooler pipe connections are + capacity?
liam012
Post Tue Mar 06, 2007 12:31 pm
you know the adapter of the block wich the oil cooler pipes screw into? what size does the pipe have to be screw into that and does anyone know cooler capacity and pipe diameter!!
thanks
this adapter>
Ant
Retired Team Member
Retired Team Member
Post Tue Mar 06, 2007 7:41 pm
Hmm, no info listed on ETK as to size/pitch of thread Liam.
will try and dig out a spare unit tomorrow and measure it up for ya fella :thumb:
anyone save me the trouble ?? :wink:
Globulator
Post Wed Mar 07, 2007 11:35 pm
The pipe measures up at 15.2mm OD, then there are little moulded ridges that do the actual sealling. Rubber O rings may alo be involved.
The thread is about 22mm OD for the male connection, didn't get round to measuring the other one - sorry.
I also learnt that if the pipes are really rusty, then they're probably welded to the oil cooler too. My attempt to cut off the 2nd nut will commence tomorrow!!
1986 325i 'vert, funk louder than standard.
"No Mr Bond, I expect you to tell me why your 4 litre, 282bhp sports car can't outrun some lardy old Mercs.."
Audio & electronic software: http://www.cutestudio.net
Post Wed Mar 07, 2007 11:47 pm
Cheapest and easiest way to deal with leaking/rusty cooler pipes is to remove them and use a 320 type oil filter arrangement.
The M20B20 doesn't have a cooler, the M50B25 doesn't have a cooler, and I doubt if the M20B25 really needs one either with modern oils.
Globulator
Post Thu Mar 08, 2007 10:59 am
Now you tell me Brian :mad: !!
If you do persevere with changing rusty pipes, the best way I found of getting the nuts off the cooler is to slice open one side of the nut with a dremel cutting disc, then take a cunk out of the opposite side, and bang in a screwdriver to wedge the nut open. Unfold the nut, and then wonder how much easier it would have been with grease in the threads!!
Brian: Is the M20B20 arrangement just a bolt-on replacement filter base for the 325? (just in case my rad ever shows a leak!).
Post Thu Mar 08, 2007 7:21 pm
it's 24mm for the oil cooler pipes and 17mm for the bolt which holds the housing
hth
