obc problem
hass
Post Sun Mar 04, 2007 10:09 pm
hi guys i own a 325i touring f reg
with some extras apart from obc :cry:
my mate is braking a 320 saloon with obc
so there i go striiping it down with somke big grin :D
then came across a problem :(
under the glove box area the loom goes to like some white square box thingy
with a couple of wires going to it from the obc loom
but my trouring has the white box but the wires i carnt seem to see where they'll go.
if any1 has done this and came across this problem let us know
also what are those wires
perment live,igntion live
earth
thanks hass
gazza
Post Sun Mar 04, 2007 10:15 pm
its all part of the seperate loom for the obc its in 2 parts and you will need all of it to be complete from the speedo and control box on the ecu right down to the white box and on into the engine compartment to the temperature sender
hass
Post Sun Mar 04, 2007 10:23 pm
right....
i have the speedo side and control box
but the other end where the wires go under glovebox is that sperate
orangecurry
Post Mon Mar 05, 2007 11:07 am
yes it is separate - it is the 2 wires that run to the temperature sensor which is located (if your car is facelift) in the air-intake duct on the near-side - take the air-intake duct from the donor car (if this car is also facelift) and replace yours with it. The wires are brown and blue IIRC
