I picked the car up from the body shop and I`m really chuffed with the job they did.
Saturday was the first time I had ever really done any work on an E30 and I had some sucess, I got the bonnet catch and cable in, a job I thought was going to be a nightmare, quite the reverse actually, it took me about 20 mins with no manual or clue as to how the front grille and headlamps came apart, well done BMW for making it all so easy to take apart, however I have found that the n/s inner headlamp asjusters are broken. Next I changed the dash insert, this all went well ish, I changed the unit itself, no problem and the rev counter now works, so does the fuel guage I think!!!! (very low fuel) one problem that has now shown itself, the battery light doesn`t extinguish once the engine has started, it did before???? also the ABS llight which did work, no longer does?????, am I right in thinking that if the temp guage needle trembles at the bottom, the nut on the back wants tightening????
I put my M-Tec steering wheel on
I did uncover some rust, I need to cut a bit out of a scrapper and get it let in, see pic.
Is this the sunroof drain tube.
This hole was full of seam sealer.
Le Mans Classic 2006
